How to turn off/on WebUI and Captive portal in MAS
Introduction : Knob to turn off/on WebUI and Captive portal in MAS
Feature Notes :
* There is a WebUI knob provided to disable or enable the Web UI of the switch.
* WebUI knob is enabled by default.
* When knob is enabled the user can access the WebUI using the switch management IP.
* When the knob is disabled user can not access the WebUI. Ports 443 and 4343 should be effectively closed when WebUI is disabled.
* Captive Portal knob is provided to disable or enable the captive portal ports of the switch.
* Captive portal knob is enabled by default.
* When knob is enabled the access for user to upstream network are allowed after providing the login and authentication details.
* When the knob is disabled user can not access the upstream network.
Environment : This is applicable from OS 7.3.1.0 and above on Mobility access switches
Configuration Steps :
(Aruba) (config) #web-server
(Aruba) (Web Server Configuration) #?
captive-portal-ports    Enable or Disable Captive Portal Ports 8080/8081
mgmt-ui-ports           Enable or Disable Webserver
no                      Delete Command
Captive Portal and WebUI disabled on Switch
(Aruba) (Web Server Configuration) #no captive-portal-ports
(Aruba) (Web Server Configuration) #no mgmt-ui-ports
Captive Portal and WebUI enabled on Switch
(Aruba) (Web Server Configuration) #captive-portal-ports
(Aruba) (Web Server Configuration) #mgmt-ui-ports
Verification :
Show Commands
(Aruba) #show web-server
Parameter                                      Value
Cipher Suite Strength                          high
SSL/TLS Protocol Config                        sslv3 tlsv1
Switch Certificate                             default
Captive Portal Certificate                     default
Management user's WebUI access method          username/password
User session timeout <30-3600> (seconds)       900
Maximum supported concurrent clients <25-400>  25
Enable/Disable Webserver                       Enabled
Enable/Disable Captive portal                  Enabled
When GUI is enabled
User-added image
When GUI is disabled
User-added image
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 01:02 AM
Updated by:
Contributors
Comments
cert seeker
AWESOME!!! Information
Is this a frequent problem?
Request an official Aruba knowledge base article to be written by our experts.
