IAP Auto-POE Priority Using MAS
Auto-POE Priority
When an IAP is plugged into a PoE enabled port on the MAS, the MAS automatically increases the PoE priority from low (default) to high. This only occurs if the poe-profile associated with the given port is using the poe-factory-initial profile and the default poe-priorty has not been manually changed.
Config
interface-profile poe-profile "poe-factory-initial"
   enable
interface-profile lldp-profile "lldp-factory-initial"
   lldp transmit
   lldp receive
   med enable
interface gigabitethernet "0/0/2"
Troubleshooting
show interface-profile poe-profile poe-factory-initial
(host) #show interface-profile poe-profile poe-factory-initial
Power over Ethernet profile "poe-factory-initial"
Parameter                         Value
Enable PoE interface              Enabled
Max Power on PoE port milliwatts  30000
PoE port priority                 low
time-range-profile                N/A
show poe interface brief
(host) #show poe interface brief
PoE Interface Brief
Interface  Admin   Consumption(mW)  Port Priority  Port Status
GE0/0/0    Enable  0                Low            Off
GE0/0/1    Enable  0                Low            Off
GE0/0/2    Enable  5700             High           On
GE0/0/3    Enable  0                Low            Off
GE0/0/4    Enable  0                Low            Off
GE0/0/5    Enable  0                Low            Off
GE0/0/6    Enable  2400             Low            On
GE0/0/7    Enable  0                Low            Off
<INTENTIONALLY SNIPPED>
From the output above, you can see that port 0/0/2 currently has a PoE priority of High. While this output alone does not necessarily indicate that there is an IAP plugged in there, you can verify it using the show lldp neighbors output as shown above.
Version history
Revision #:
1 of 1
Last update:
‎07-11-2014 01:58 PM
Updated by:
Labels (1)
Contributors
