Mobility Access switch (MAS) supported versions for Aruba Central
MVP
MVP
Q:
What are the supported versions of Mobility Access switch (MAS) for Aruba Central?
A:
MAS supported versions are 7.3.2.0 and above.
Version history
Revision #:
2 of 2
Last update:
‎08-04-2015 05:36 PM
Updated by:
Labels (1)
Contributors
