PoE Alarms
MVP
MVP
Q:
Is there any way to detect receiving power from another PoE source in Aruba Mobility Access Switch?
A:
Yes, starting from ArubaOS 7.3.2.1, a new alarm, Inline Power Detected On <slot/port/module> is introduced  in the Mobility Access Switch to indicate that an interface is receiving power from another PoE source. This major alarm is indicated by the Status LED in the front panel with a blinking amber. You can view the active alarms using the show alarms command.
The following sample indicates that the interfaces GE0/0/1 and GE0/0/13 are receiving power from another PoE source:
(host) #show alarms
2 Active Alarms in the System
Class Time Description
Major 2014-06-19 14:12:38 (IST) Inline Power Detected On GE0/0/1
Major 2014-06-19 14:12:57 (IST) Inline Power Detected On GE0/0/13
Version history
Revision #:
2 of 2
Last update:
‎02-11-2016 01:16 PM
Updated by:
Labels (1)
Contributors
