S1500 Fan Speeds - FAQ
An insight into the various temperature range and fan speed comparison
There are multiple fans in the S1500 (as you can see from the show command).  The two system fans (FAN 0 and FAN 1) operate independently from the two power supply fans (Power Supply Fan 0 and 1).
The system fans operate only in relation to one temp sensor (the “CPU” temp in the CLI):
TEMPERATURE
(CPU)
FAN SPEED (RPM)
0-58 3500
59-70 7500
71+ 10000
The power supply fans operate primarily in relation to PoE load:
POE Load (W) FAN SPEED (RPM)
0-50 4000
50-100 5000
100-200 6000
200+ 7500
However, the PoE load may be overridden by the temp, although a different sensor than the system fans.  The “console” temp in the table below is actually the “ambient” temp shown in the CLI.
TEMPERATURE
(CONSOLE)
FAN SPEED (RPM)
0-33 4000
34-45 10000
46+ 16000
Version history
Revision #:
1 of 1
Last update:
‎06-27-2014 06:57 AM
Updated by:
Labels (1)
Contributors
Tags (2)
