WHAT TO DO WHEN A STACKING MEMBER GOES TO DORMANT(C ) STATE?
SETUP:
PRIMARY- SECONDARY & TWO LINE CARDS.
Please use the following command to show the state of the switches
(ArubaStack) (stack-profile) #show stacking members
Member status: Active, Stack Id: 001a1e087b004fcee152
Stack uptime: 4 hours 24 minutes 50 seconds
Id    Role       MAC Address     Priority  State        Model            Serial
0  *  Primary    001a.1e08.7bc0  Preset    Active       ArubaS2500-48T   AK0000020
1     Secondary  001a.1e08.7a80  Preset    Active       ArubaS2500-48T   AK0000017
2     Linecard   001a.1e08.7b80  128       Dormant [C]  ArubaS2500-48T   AK0000018
3     Linecard   001a.1e08.7c80  Preset    Active       ArubaS2500-48T   AK0000014
Dormant(c)- Present configuration mismatch
The switch goes to this state as the Serial number of this line card is not added to the Stacking database.
Please use the following command to add the Serial number back to the Stacking database.
ArubaStack) (stack-profile) #member-id 2 serial-number AK0000018 role line-card
WARNING!! This profile will not be applied till the configuration is saved.
(ArubaStack) (stack-profile) #write memory
Saving Configuration......
Execute the command again to confirm if the status is back to active.
Stack uptime: 3 hours 14 minutes 49 seconds
2     Linecard   001a.1e08.7b80  Preset    Active    ArubaS2500-48T   AK00000183
Version history
Revision #:
1 of 1
Last update:
‎08-06-2014 08:46 AM
Updated by:
Labels (1)
Contributors
Comments
This is a good start, but what about when the switch is 'dormant' and the role is "na" and the stack ID is "?".  The fix in this article unfortunately does not help in this situation.
