What will take precedence if we configure an interface with is part of a interface- group ?
Environment : This article applies to all Mobility Access Switches running a minimum AOS version 7.3.0.0
When we configure an interface that is a member of an interface- group, applying a non-default profile or a parameter to the interface takes precedence over the interface- group configuration.
By default, all the interfaces belong to a default interface- group.
(ArubaS2500-48P) #show interface-group-config gigabitethernet default
gigabitethernet "default"
Parameter                                        Value
Interface group members                          ALL
Interface MSTP profile                           default
Interface GVRP profile                           N/A
< output truncated >
Version history
Revision #:
1 of 1
Last update:
‎06-27-2014 03:42 PM
Updated by:
Labels (1)
Contributors
