Contributor I
AP boots as only AM mode.
I use rw7010 and ap205 converted from iap.
but when I assign the ap to controller , it boots as only AM mode despite both of them use default profile.
the procedure is below.
1. Set IP address to the factory-default-7010. -----ex.172.16.0.1
2. Enter *convert-aos-ap cap 172.16.0.1* command to the iap205.
3. After AP reboots, 7010 finds the ap205 as AM mode...
4. try purgeenv for the ap, but there is no difference.
i want to use normal cap mode.
please give  me any advise.
Thanks in advance.
Regards
Atsushi Ikeda
Super Contributor I
Re: AP boots as only AM mode.
Have you checked to see if the AP-205 is supported in your regulatory domain?
ACDX #419 | ACMP |
Please look here:  https://pctools.arubanetworks.com/compliance/ to see if the AP205 (APIN0205) is approved for your country's regulatory domain.
Contributor I
Thank you for quick reply. Yes, it supports my domain. The other ap205s has no problem. one ap205 only... have you got any suggestions ?
On the commandline, type "show ap database long" to see if your access point has any flags that would indicate why.
Contributor I
Thank you. There is no flag deisplayed from that command !
Is it in the default ap-group, or in a special ap group?  Does the ap-group that it is in have the radios disabled?
Contributor I
It is in default group because it remains default config except ip address. so both radio is enable.
And I connected another 205 to the controller,then it booted up as cap in the same default group...
Please tell me if I should get specfy log.
Thanks.
Type "show log system 50" and see if anything references your AP.
Contributor I
O.K. I atatch its log.
I saw AM mode ap in that log..
But I couldn't catch the any information about AM mode boot...
