1 SSID is much slower than the other SSID
I have two SSIDs on our Aruba Wireless Network. They are getting vastly different network speeds, especially on the upload. What could cause this discrepancy?
Settings:
•Both are set to "Primary usage: Employee".
•Broadcast filtering: All
•Client IP assignment:
     SSID 1: Network assigned
     SSID 2: Virtual Controller managed
     (Different subnets)
Hardware:
•6x IAP-205
Speed test results (The test was done on both SSIDs while connected to the same Access Point. I tested multiple access points and got similar results)
SSID 1:
Download 38.83Mbps
Upload 91.28Mbps
SSID 2:
Download 14.80Mpbs
Upload 0.56Mbps
Any advice about this would be appreciated!
Thank you
