11n A2400 CONTROLLER
  • 1.  11n A2400 CONTROLLER
    Posted Feb 28, 2013 12:22 AM
    my customer have a Aruba2400 controller, 30 AP-65 , 5 AP-80M, he want to migrate in  to 11n AP first and later migrate to 3400 controller, my doubt is if we use a new AP 11n capable with the 2400 controller it will work fine? or the 2400 controller is not capable to deliver the 11n?
    #3400
  • 2.  RE: 11n A2400 CONTROLLER
    Posted Feb 28, 2013 12:51 AM
    Hi
    :smileyhappy:
    the 2400 isn't cert 802.11n controller,But it can run ArubaOS in version 5.X <- so u can start using your Aruba (N)AP - that supported by 5.X version.
    what is your AP model?
    (THE AP-68,THE AP-92/93/105/124/125/174 WILL WORK)
    have a lovely day.
    me
  • 3.  RE: 11n A2400 CONTROLLER
    Posted Feb 28, 2013 12:54 AM
    i upgrade the controller to 5.0.3 version, and im planning to install AP175 and AP105, my concern is fi those AP's will work fine in 11n?..
  • 4.  RE: 11n A2400 CONTROLLER
    Posted Feb 28, 2013 12:57 AM
    Yes they will work fine. (see the attached table i added to my first post)
    Just be aware that the 2400 eth ports are 10/100 and not 10/100/1000 <-if u planning to give 300MbpsX2 with band sterring and a lot of clients on AP-105 , or on the AP-175 you should be aware to this port limit.
    me
  • 5.  RE: 11n A2400 CONTROLLER
    Posted Feb 28, 2013 01:33 AM
    ok thanks!!
  • 6.  RE: 11n A2400 CONTROLLER
    Posted Feb 28, 2013 01:06 PM
    do you know if the AP-80M can work  on AOS 6.1?
