130 - 150 clients?
I was wondering what AP would work best to support 130-150 clients in a classroom setting?
I have a ap-105 currently and i max it out around 95 clients.
Any ideas?
Thanks in advance!
Re: 130 - 150 clients?
AP-225, assuming a more or less even split of clients across both radios.
What do you see with your AP105s, when you say it maxes out? Will client #96 not get on, or is it just performance-related? Also, what split of clients between 2.4Ghz and 5Ghz are you seeing per AP?
Jerrod Howard
I am receiving a message of ( This AP has reached maximum capacity and cannot accommodate accommodate any more clients)
so the 96th client will not be able to get onto the AP .
On That AP I see that about 2/3 of our clients are on 5ghz.
I have 2 other 105's close by but the clients wont jump to the other 105's.
And what is your max associations set to per SSID and/or in the AP system profiles? You might be able to raise that up a bit to get more on there (you should be able to technically, though whether performance will be great is a whole nother matter heh).
Jerrod Howard
