16 Lan AND 2 wired on a 650
Hi All, can a 650 support 16 LAN connected access point s AND 2 direct connected AP's at the same time (total of 18?)
Re: 16 Lan AND 2 wired on a 650
No.  16 is the maximum.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks! :-)
