160 MHz Beacons with IAP-315
Hey AirHeads!
I'm doing some light lab work (don't worry, not an actual deployment) with an Aruba IAP-315 with Instant, and I need to get a beacon advertising a 160 MHz channel.
It looks like the AP is capable of 160 MHz channels, but I can't find how to configure that in the Instant GUI. Perhaps I need to get into the CLI?
Re: 160 MHz Beacons with IAP-315
Hey, I don't have IAP-315 to hand but I do have a IAP-225 and it does support 80MHz w, so i'm wondering if the same options are on the IAP-315 but for 160mhz.
Under the "RF" settings and then the "Radio" tab,  have you enabled "Very high throughput" to enable 11ac?  Then again under "RF", I have the option to enable 80MHz support, do you have the same options for 160MHz support?
Cheers,
Craig
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Contributor I
It's seem like software on IAP still doesn't support 160Mhz yet, but i have tried with controller mode It's can working on 160Mhz, If you have a controller just go to looking rf profile.
Anyone have news about this limitation ?
I have an Aruba IAP-314 and it seems not possible to configure 160MHz >
AP01# show ap allowed-channels
Allowed Channels for AP Type 324 Country Code FR
PHY Type Allowed Channels
802.11g (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
802.11a (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
802.11g (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
802.11a (outdoor) 100 104 108 112 116 120 124 128 132 136 140
802.11g 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
802.11a 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
802.11g 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
802.11a 40MHz (outdoor) 100-104 108-112 116-120 124-128 132-136
802.11a 80MHz (indoor) 36-48 52-64 100-112 116-128
802.11a 80MHz (outdoor) 100-112 116-128
802.11a 160MHz (indoor) None
802.11a 160MHz (outdoor) None
802.11a (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
Thank you
I'm not super surprised that it doesn't actually support 160 MHz channels, as there's almost no real-world application for them. I was hoping to use a 160 MHz channel to test my company's Wi-Fi scanner, but I have yet to find an AP that will beacon 160 MHz support. It would probably be easier for me to just make a fake beacon. :)
Cisco 3800 might also be an option. Probably won't have time to find out.
It is dependent on your regulatory domain:
(Aruba7640-US) #show ap allowed-channels country-code US ap-type AP-315
Allowed Channels for AP Type AP-315 Country Code "US" Country "United States"
802.11a (indoor)          36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
802.11a (outdoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
802.11a 40MHz (indoor)    36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 140-144 149-153 157-161
802.11a 40MHz (outdoor)   36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 140-144 149-153 157-161
802.11a 80MHz (indoor)    36-48 52-64 100-112 116-128 132-144 149-161
802.11a 80MHz (outdoor)   36-48 52-64 100-112 116-128 132-144 149-161
802.11a 160MHz (indoor)   36-64 100-128
802.11a 160MHz (outdoor)  36-64 100-128
802.11a (DFS)             52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
