Contributor I
2* 2 ap with Transmission Power 26dbm/400mW
Please suggest indoor AP model with below config:-
1) 2* 2 ap with Transmission Power 26dbm/400mW
Out door AP
1) AP with 16dbi antenna
Re: 2* 2 ap with Transmission Power 26dbm/400mW
Mohan007,
For the indoor access points, please use the product finder here:  http://www.arubanetworks.com/products/networking/access-points/
There are few indoor access points that can output 26dbm.
For outdoor access point antennas, please look here:   http://www.arubanetworks.com/products/networking/antennas/
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
thanks for your reply, I checked but no model give output power more than 23dbm(110 series), can u please help .
I am looking for an antenna based model.
That is because it does not really exist. Where did you get those numbers from? What is your deployment need?
Contributor I
There is a RFP where we want to bid for Aruba, hence the requirement. Enclosed is the rfp doc...
Thanks in advance
