2.4ghz and recommended tx
Why    3dB(tx ) recommended  for   a pre (2.4 ghz)?
Thank you
Super Contributor I
Re: 2.4ghz and recommended tx
It says 9dBm EIRP. External antennas?
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
it's from a survey tool demo video
#AirheadsMobile
what will be the best for internal antennas
#AirheadsMobile
