Regular Contributor I
2 NPS Servers on 1 SSID with 2 different active directorys
Hi community,
is it possible to congfigure on 1 ssid 2 radius server (we use ms 2008r2 nps) to authenticate the users in different domains.
first nps is for domain 1
second nps is for domain 2
I wan if nps domain 1 rejects the authentication the controller asks nps domain 2 to authenticate the user.
Is this possible? how can I configure this?
Re: 2 NPS Servers on 1 SSID with 2 different active directorys
Did you try using the Fail-Through option on the Server Group?
Zach Jennings
Leon123 wrote:
Hi community,
Yes, you can enable "fail-through" on the server group with the two servers in it, BUT here are the requirements:
- If you are using 802.1x you need to enable "Termination" in your 802.1x profile on your Aruba Controller (http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Radius-server-failover-in-1x/ta-p/93788)
- You will also need to create and upload a server certificate for 802.1x to your Aruba controller and the clients in both domains must trust the CA that issued the server certificate and/or the server certificate specifically
