2400 os 3.4.3 reset
Greetings everyone,
Clearly I am new here.  I just picked up a used 2400 controller and attempted to follow the password reset proceedure outlined a dozen other places here on the board. (user: password, pass:forgetme!)  I do this connected via console
However, I am not able to enter privlidged mode to change mgt-user because it asks me for an enable password, which when I provide it with forgetme!  does not seem to work.
The OS version on this is 3.4.3, is there an alternate recovery method I can employ? (does it have a rommon mode like cisco?)
Thanks in advance.
Kory
Valued Contributor I
Re: 2400 os 3.4.3 reset
Username and password are correct.
Enter "enable" for the enable/priviledge secret. Then conf t and reset the admin mgmt password.
When you log back in from scratch, enable is still "enable".
Good luck!
Kudos appreciated, but I'm not hunting! (ACMX 104)
Thank you!
Had to be something simple that I missed.
Have fun with the new toy!
