Contributor II
25+ RAPs fail to register after unexpected reboot controller
On of our controllers reboot due to a power failure, as a result 25+ RAPs fail to connect. The following error message is in the log:
Apr 28 15:37:17 sapd[822]: <311020> <ERRS> |AP GDF-RAP37-G16B@192.168.114.122 sapd| An internal system error has occurred at file sapd_msg.c function sapd_hello_cb line 6529 error Unexpected result code (null).
We run a 3600XM with the latest software;
ArubaOS (MODEL: Aruba3600), Version 6.4.3.7
Some suggestions about how to troubleshoot would be much appreciated.
Re: 25+ RAPs fail to register after unexpected reboot controller
I would open a TAC case, because they would probably need much more information than that to find out what is happening.
Contributor II
I created a TAC case but unfortunately our contact ended a few weeks ago, and the order for the new contact is somewhere in the process of being accepted and processed. I hope they will accept this and give support anyway, we will see.
Contributor II
I am troubeshooting this myself, untill I can get a hold on a valid contract.
I see rather strange behaviour, the RAPs don't connect with the controller. Somehow the RAP nats all traffic to his WAN ip and drops it on our LAN. Is this by design? I have not noticed this before.
PS we use RAPs on our LAN to tunnel guest and contractor traffic on production sites.
Any chance you can provide some further information which might help us diagnose the issue? If you run the following via the CLI
#show ap database long
- Is there any flags next to the RAP's?
#show datapath session | include xxxxx
- Where XXXX is the outer IP of the RAP.
#show log all | include xxxx
- Where XXXX is the name of a RAP
#show control-plane-security
- Is control plane security enabled?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Contributor II
Thank you for your reply.
I found this in the logs
Apr 29 10:06:35  stm[1953]: <305059> <WARN> |stm|  Version 6.4.3.7 is not compatible with AP GDF-RAP37-G16B with type RAP-5WN, mac 00:0b:86:69:54:c2
Seems like the software version on the controller is not compatible with the RAPs.
I guess I will have to figure out to update the software running on the RAPs.
The latest supported OS for a RAP5-WN is ArubaOS 6.3, so the code you are running isn't supported.
You can see this from the EOL doc below :
http://www.arubanetworks.com/support-services/end-of-life/
Is it possible one of the image paritions has been upgraded on the controller but not activated? When the controller rebooted it may have booted into the parition with the later firmware? You can check this with
#show image version
- Will display the software versions running on each parition
# boot system partition X
- Will inform the controller to boot into partition X (as seen in the above command) on the next reboot.
ACMA, ACMP, ACSA
Contributor II
That should be it! I will downgrade to the latest 6.3 release.
Thanks for your insight :)
(DHARUBA02) #show image version
Partition : 0:0 (/dev/hda1)
Software Version : ArubaOS 6.3.1.21 (Digitally Signed - Production Build)
Build number : 54002
Label : 54002
Built on : Mon Feb 29 00:04:58 PST 2016
Partition : 0:1 (/dev/hda2) **Default boot**
Software Version : ArubaOS 6.4.3.7 (Digitally Signed - Production Build)
Build number : 53990
Label : 53990
Built on : Sat Feb 27 13:11:21 PST 2016
Great stuff, glad to hear it :D
ACMA, ACMP, ACSA
Contributor II
Pretty sloppy of me tbh, I was convinced the RAPs were already working on a prior 6.4 release.
Thanks again!
