293 RAPS in front of M3 Controller - what is the bandwith of wan side of the controller? split
Hi Guys,
I have a deployment with 293 RAP units (AP-68 in RAP-MODE)  in front of M3 Controller 6.1.3.8 - what is the bandwith that i need at the wan side of the controller?
Im working on each RAP with captive portal -> split-mode. (after the clinet are succesufly login - of their trafiic ..except DHCP is going via the AP in split-tunnel/route-src-nat
please advise? ? Today there is 10Mbps/10Mbps on the wan port of the controller..and it's seems that in some spesefic hours the captive portal redirect taking too long.
please advise.
Thanks in advance
Me
Re: 293 RAPS in front of M3 Controller - what is the bandwith of wan side of the controller? split
Anyone?
I've attached the estimates from the VRD, hope this helps :)
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Thanks!
