Frequent Contributor I
304 and ap-ant-35 / 38
Hi!
Just wondering does it matter which antennacable I plug in to which ant0-2 connection on ap304 ? ie ant-35 has 3 cables labeled 45 45 and 90. IAP-304 has ant0,1,2. Does it matter wich I connect to wich ? I simply go first to 0 and so on now.
Can´t seem to find anything on this so I´m guessing it maybe doesn´t matter.
/Daniel
ACMP | ACCP | HP ATP - FlexNetwork Solutions
Aruba
Re: 304 and ap-ant-35 / 38
It does not matter. As long as you connect all three  ;-)
/Onno
Thanks , just making sure :)
/Daniel
