cdj
Contributor I
3200 Controller Not taking ap group or virtual ap commands
We have a lab controller, I erased the config and put a new config on the controller but when I try to input an ap group or virtual ap, the command is not accepted.
Is there something that needs to be enabled?
We have a 3200 controller running 3.4.5.1
Re: 3200 Controller Not taking ap group or virtual ap commands
Do you have a root login?
Hopefully you did not configure it as a local controller....
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Did you wip away the licenses?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Is that controller configured as a local controller ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
