Frequent Contributor II
3400 Controller
I have a defaulted 3400 controller, re-porvisioned AP's and when I connect to the SSID and open google maps\maps its telling me my location as China.  I have confirmed that the time zone is set correctly on the controller.  The OS running is 6.3.1.6.
Any thoughts?
Re: 3400 Controller
The location is based off your IP space/ISP, not any information from your wireless controller.
Tim Cappalli | Aruba Security
Re: 3400 Controller
Thanks for the response.  The controller was over in China for a show and once it was brought back here it was reset and it's showing my maps application that I am in China still when connecting to the SSID that it's broadcasting.  Any other possibilities that would cause this?
Super Contributor I
Re: 3400 Controller
It gets this information from your public IP address. If it's still somehow source nat'ing to something in China then that would be why.
ACDX #419 | ACMP |
