3400 RAP/CAP Licensing Clarification
We have an Aruba 3400 controller we have recently been asked to support. I'm not 100% sure about how Aruba licenses it APs within WLC's. Can anyone help clarify the following for me please:
1) What is the difference between a CAP and a RAP?
2) Are the any Aruba documents that explain the controller licensing overall?
2) We have 49 APs active on the WLC made up of 6 x AP105 and 5 x AP68's 38 x AP65 however the the controller is showing 46 CAPs and 3 RAPs. What defines when a CAP license entry is used compared to a RAP license?
(Aruba-master2) #show ap license-usage
AP Licenses
Type Number
AP Licenses 64
Overall AP License Limit 64
AP Usage
Type Count
CAPs 46
RAPs 3
Remote-node APs 0
Tunneled nodes 0
Total APs 49
Remaining AP Capacity
Type Number
CAPs 15
RAPs 15
Thanks all in advance.
Aruba
Re: 3400 RAP/CAP Licensing Clarification
CAP (Campus AP) and RAP (Remote AP) are the two designations APs have when terminating on a controller.  A CAP is typically an AP within your organizations physical locations while RAPs are usually at remote sites or for home users.   The RAPs terminate on the controller via IPsec.   The following links may help explain some of it.
Campus Deployments:
Remote Deployments:
Remote Access Points
http://www.arubanetworks.com/vrd/ControllerVRD/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap3.html
Each CAP or RAP consumes an AP license (assuming ArubaOS 5.x or later).   If an AP is configured as a Remote AP it will show as RAP vs. CAP.  To determine which APs are RAPs, run the following on your controller (you may get some non-RAPs as part of this command depending on the names of your APs, but look for the "R" in the flags column.
show ap database | include R
AMFX | ACCX | ACDX | ACMX
MVP
Tons of good answers in this thread so I won't go into details on that other than.. If you need to reach the controller across internett then you need RAP (tunnel traffic using IPSec to the controller). Campus AP is on the same LAN/WAN network as the Controller and terminate using GRE.
Difference-Between-Campus-AP-and-Remote-AP-Where-we-deploy-them
You need the same licensing for both types, but a Controller can handle 4x as many RAP as CAP. So if you dedicate a 3400 controller for RAP you will be able to connect 64 x 4 = 256 RAP. If you mix CAP and RAP you will have to do your math so the total isn't above 64 CAP - like 30 CAP and 34*4 RAP.
Overall? Well - this will give you a list.
So normally you will at least need AP and PEF-NG (firewall license) in equal amounts. Without the PEF-NG you can only have one SSID - like a plain guest network with allowall access.
Well - the Access Point is provisioned as a RemoteAP and is listed as such. There used to be different licensing for CAP and RAP back in pre 5.x, but not since then.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Occasional Contributor I
I am very much aware of the x 4 ratio of supporting RAPs vs CAPs, however in recent offical Aruba controller matrixs, its showing equal number of RAPs vs CAPs support for 600 series controllers and 7000 series cotrollers, but not for 3000 series controllers which still show the x 4 capacity for RAPs vs CAPs?
Is this documentation wrong?  Or is Aruba converting to an equal 1:1 CAP:RAP capacitiy limits for 600 and 7000 series controllers?
Is there a software code that is associated to this change in capacity?
Trusted Contributor I
indeed this is quite confusing.
for example here: http://www.arubanetworks.com/pdf/products/matrix-mobility-controller.pdf
please Aruba this has been mentioned a few times here now, make sure this gets clarified. in my opinion stop with this 1:4 stuff totally.
