Contributor I
3400 controller login issue
I have configured an aruba 3400 controller. After entering all the config,. the login ( CLI or WEBGUI) is taking an extremely long time. ANy troubleshooting ideas ?
Frequent Contributor II
Re: 3400 controller login issue
Is this a new install?
Have you got RADIUS auth enabled?
Slow login on WebGUI + SSH + serial console?
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
Can you get console access?
- Make sure that all your VLANs and Port are trusted
- You should consider disabling STP on the controller too and allow the upstream switch do the STP
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
Yes, slow on WEBGUI+SSh+Cli
Contributor I
Ports are trusted and STP is disabled
Does this controller have high CPU usage?
"show cpuload"
"show cpuload current"
www.securelink.nl
Contributor I
CPU usage 0.1%
Try restarting the controller
Did you removed the IP address of VLAN 1?
Thank you
Victor Fabian
Contributor I
Actually , found the issue !
We were authenticating against a radius server instead of internal auth.
THat caused the time lag.
Thank you for all your input eveyrone !
