Currently have 2 interfaces assigned to port-channel ID 0. Want to move them to port-channel ID 1. Via the GUI, Configuration > Network > Ports > (Port) select one of the ports and from the LACP Group dropdown change from 0 1 and click apply and receive the following error:
GigabitEhternet 1/1 :Error:Port is a member of different port-channel grop
From Configuration > Network > Ports > (Port Channel) select ID 0 and deselect port 1 from it and click apply and receive the following error:
Pc-0 is controlled by LACP
Please advise as the correct manner in which to remove both ports from ID 0 to ID 1.
Tony Marques
