3600 as a Master Capacity
Hi All,
if I am using a 3600 as a central master controller for a large network. How many remote \ local controllers can this supoport?
How is it calculated - total number of APs on the local controller or number of users etc... Thanks for your help.
Re: 3600 as a Master Capacity
Please refer to the following VRD (Validated Reference Design) on page 112.
http://www.arubanetworks.com/pdf/technology/DG_Mobility-Controllers-Deployment-Models-5.0-VRD.pdf
The scaling values are shown there.
Mark
Thanks MVERBLOOT, this answers my question exactly.
Have saved the link for future reference too.
Thanks.
i am not able to access above link.
i am looking for max. no. of users that 3600 controller can handel at a time.
Aruba
The 3600 can handle 8192 concurrent devices;  see dataheet:
http://www.arubanetworks.com/pdf/products/matrix-mobility-controller.pdf
As a Master, the guides (links) have been since updated.  The numbers below are if the controller is a Master; so the numbers are referrimg to the cumulative nuimbers; including the locals.
Try this:
Page 63
http://www.arubanetworks.com/wp-content/uploads/MControllerVRDV9.pdf
AMFX | ACCX | ACDX | ACMX
