I have a spare 3600 that I am using to perform upgrade testing from 3.3.3.10 to 6.1.3.1. The production 3600’s are running 3.3.3.10. To start the upgrade testing I reset the config on the spare which is running 3.3.3.10. I attempted to put in the config that is running on the production on to the spare from config t, but many of the commands are not taken, and if I try to find the command using the “?” they are not even listed as commands. But both are 3600’s and both are running 3.3.3.10. Seems I must be missing something obvious!
(ArubaTest) (config) #netdestination Public-DNS
% Invalid input detected at '^' marker.
(ArubaTest) (config) #ip access-list
(ArubaTest) (config) #vpn-dialer default-dialer
(ArubaTest) (config-vpn-dialer)#ike authentication PRE-SHARE dontknow
(ArubaTest) (config-vpn-dialer)#ike authentication PRE-SHARE ?
(ArubaTest) (config-vpn-dialer)#ike authentication ?
(ArubaTest) (config-vpn-dialer)#ike ?
(ArubaTest) (config-vpn-dialer)#?
no Delete Command
Of course if I try any of these commands in production they are all legit. What am I doing wrong here?
#3600
