MVP
3600 shows 512 max APs in Inventory tab.
Question from twitter: Have you guys seen this?
Why the wlc 3600 shows maximum APs number 512 ??!!! In the inventory tab while it should be 128??!
Sean Rynearson
Re: 3600 shows 512 max APs in Inventory tab.
Version of ArubaOS?
It can have 128 campus APs, or 512 RAPs.
ACCP, ACCX #817, ACMP, ACMX #294
