Contributor I
3600 with public IP
Hey guys,
I have a controller with a public IP and I can ping and access the controller from any computer... I would like to create a NAT like the Pic below..
If I connect a computer to the controller I have a DHCP IP but no internet.. I'm pretty sure im missing something in the DNS seetings.. Do I have to setup  Vlan 10 from scratch with public IP , netmask, gateway? what about DNS should I setup DNS then import DNS on Vlan 20 and use the gateway from vlan 10?
I'm pretty sure is something simple, can you guys please help me?
Thanks!
Gio.
I have 2 Vlans..
vlan 10
vlan 20
vlan-name Default
vlan-name INSIDE
vlan INSIDE 20
vlan-name OUTSIDE
vlan OUTSIDE 10
interface gigabitethernet 1/0
description "GE1/0"
trusted
trusted vlan 1-4094
switchport access vlan 10
interface gigabitethernet 1/1
description "GE1/1"
trusted
trusted vlan 1-4094
switchport access vlan 20
interface gigabitethernet 1/2
description "GE1/2"
trusted
trusted vlan 1-4094
interface gigabitethernet 1/3
description "GE1/3"
trusted
trusted vlan 1-4094
interface vlan 10
ip address 66.1.131.5 255.255.255.0
interface vlan 1
ip address 172.16.0.254 255.255.255.0
interface vlan 20
ip address 192.168.1.2 255.255.255.0
ip nat inside
ip default-gateway 66.1.131.1
uplink disable
ip dhcp excluded-address 192.168.1.0 192.168.1.10
ip dhcp pool default-pool
dns-server 172.16.0.254
lease 0 0 10 0
no vendor-class-identifier
network 172.16.0.0 255.255.255.0
authoritative
ip dhcp pool INTERNAL
default-router 192.168.1.1
dns-server import
domain-name test
lease 0 8 0 0
network 192.168.1.0 255.255.255.0
authoritative
service dhcp
Frequent Contributor II
Re: 3600 with public IP
A couple questions...
When you say you can't access the internet, do you mean webpages are not loading on your computer?
What do you mean by setup VLAN 10 from scratch?
Is this computer wired or wireless? If wireless, what sort of role is being assigned? Any ACL's being applied to any of the controller's interfaces?
Can you ping your ISP's gateway from the controller? It may not be pingable, but usually they are.
Can you ping a public IP like Google servers (4.2.2.2 or 8.8.8.8)?
If you can ping those public IP's from the controller, can you ping them from your computer? If not, then you definately have a routing/NAT issue going on. If you can, then probably DNS. Try changing your DHCP DNS servers to a public DNS server provided by your ISP or Google.
Network Engineer | Airhead | Titus 3:5
Aruba
Your DHCP pool looks like it may be incorrect.   Pleae validate.
default-router 192.168.1.1    (your controller is 192.168.1.2; if you are doing ip nat inside, you'll want .2 to be your gw)
dns-server import       (do your clients get DNS servers assigned?   You do not have a DHCP interface, so there is nothing to import)
domain-name test      (should be valid domain name, not a big deal)
lease 0 8 0 0
authoritative
AMFX | ACCX | ACDX | ACMX
