Frequent Contributor I
4 AP's model 105. One of them is unable to broadcast SSID's. HELP
I have a controller model 620 and 4 AP's model 105. Three AP's are able to broadcast SSID's but one AP is not able to broadcast. However its getting an ip address from the controller. DHCP enabled on the controller
Console output of the APis mentioned below. Kindly help me in this regard.
apboot> purg
Un-Protected 1 sectors
.done
Erased 1 sectors
Writing
apboot> save
Saving Environment to Flash...
.done
Erased 1 sectors
Writing
apboot> boot
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
eth0 up: 100 Mb/s full duplex
DHCP broadcast 1
DHCP IP address: 172.16.0.4
DHCP subnet mask: 255.255.255.0
DHCP def gateway: 172.16.0.254
DHCP DNS server: 8.8.8.8
DHCP DNS domain:
Controller address: 172.16.0.254
Using eth0 device
TFTP from server 172.16.0.254; our IP address is 172.16.0.4
Filename 'mips32.ari'.
Load address: 0x2000000
Loading: ############T #####################################################
done
Bytes transferred = 5713900 (572fec hex)
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Automatic boot of image at addr 0x02000000 ...
ELF file is 32 bit
Loading .text @ 0x80e00000 (5645032 bytes)
Loading .data @ 0x813622f0 (32 bytes)
Clearing .bss @ 0x81362310 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing.....................................................
ú
Aruba Networks
ArubaOS Version 6.2.1.2 (build 38532 / label #38532)
Built by p4build@cyprus on 2013-05-30 at 17:58:04 PDT (gcc version 4.3.3)
CPU Rev: aa
71x CPU
Flash variant: default
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 120960k/131072k available (1920k kernel code, 10036k reserved, 756k data
, 4740k init, 0k highmem)
 available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=21280256
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ...........................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
.<6>lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Domain Name: arubanetworks.com
No panic info available
apfcutil: sector CACHE: Cache uninitialized
Testing TPM... Passed
apfcutil: sector RAP: Cache uninitialized
apfcutil -c RAP: Uninitialized. Initializing.........
apfcutil: sector MESH Prov: Cache uninitialized
ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count    400
AG7100: Max rx descriptor count    252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: d8:c7:c8:c2:38:be
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
AP xml model 39, num_radios 2 (jiffies 6533)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
setting bond0 as bridge child
setting gre0 as split child
Starting watchdog process...
Getting an IP address...
ag7100_ring_alloc Allocated 4800 at 0x86bee000
ag7100_ring_alloc Allocated 3024 at 0x869e4000
AG7100: cfg1 0xf cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0 phy is up...RGMii 100Mbps full duplex
AG7100: pll reg 0x18050010: 0x1099  AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0x7ffef
AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
Writing 4
172.16.0.4 255.255.255.0 172.16.0.254
Running ADP...Done. Master is 172.16.0.254
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Right
s Reserved
ath_rate_atheros: Aruba Networks Rate Control Algorithm
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_spectrum: Version 2.0.0
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserve
d
ath_pci: 0.9.4.5 (Atheros/multi-bss)
wifi0: Base BSSID d8:c7:c8:a3:8b:e8, 8 available BSSID(s)
bond0 address=d8:c7:c8:c2:38:be
br0 address=d8:c7:c8:c2:38:be
wifi0: AP type AP-105, radio 0, max_bssids 8
wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
wifi1: Base BSSID d8:c7:c8:a3:8b:e0, 8 available BSSID(s)
wifi1: AP type AP-105, radio 1, max_bssids 8
wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
ath_ahb: 0.9.4.5 (Atheros/multi-bss)
Starting FIPS KAT ... Completed FIPS KAT
shutting down watchdog process (nanny will restart it)...
        <<<<<       Welcome to the Access Point     >>>>>
~ # cert_cap=0
BUG: soft lockup detected on CPU#0! stuck for 10002 ms!
Cpu 0
$ 0   : 00000000 00805128 00000000 00060100
$ 4   : 00000006 bf000008 00060100 00000008
$ 8   : 00060000 ffffffff 00000001 00060100
$12   : 00060000 00070000 bf00000c 20f3946e
$16   : 004b0000 0000004c 0000004c 87d026a0
$20   : 00010000 80360000 87689e74 00000000
$24   : 00000000 8021d97c
$28   : 87688000 87689e18 87bf0000 8021da44
Hi    : 00000000
Lo    : 0000004b
epc   : 8021d244 ar7100_spi_poll+0x44/0x8c     Tainted: P
ra    : 8021da44 ar7100_flash_erase+0xc8/0x164
Status: 1000d403    KERNEL EXL IE
Cause : 50808000
PrId  : 00019374
Unwound Call Trace:
[<80114828>] dump_stack+0x8/0x40
[<80112ae8>] timer_interrupt+0x8c/0x21c
[<8014e3c4>] handle_IRQ_event+0x5c/0xb8
[<8014e4d4>] __do_IRQ+0xb4/0x140
[<8010dc0c>] do_IRQ+0x1c/0x34
[<8010292c>] ar7100_interrupt_receive+0xec/0x100
Re: 4 AP's model 105. One of them is unable to broadcast SSID's. HELP
Please open a case for these matters.  That is your best bet.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
