40 Mhz on ArubaOS 8 and ap-105
Hi All,
I'm running an ArubaOS 8 testsetup consisting of
1 Mobility Master 8.0.1.0
1 VMC 8.0.1.0
1 AP-105
I've got connectivity but I'm unable to make the ap use channel-bonding. I've done all the config at the /md node. I've attacted the config. AP is provisioned in ap-group Diekgait:
(DL-ArubaMM-02) [md] #show ap database
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
AP01 Diekgait 105 192.168.1.8 Up 4h:15m:25s 2 192.168.1.201 0.0.0.0
But it does not select a bonded channel:
(DL-ArubaVMC-01) #show ap bss-table
fm (forward mode): T-Tunnel, S-Split, D-Decrypt Tunnel, B-Bridge (s-standard, p-persistent, b-backup, a-always), n-anyspot
cluster (cluster role): U-UAC, A-AAC, sU-Standby UAC, sA-Standby AAC
Aruba AP BSS Table
bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t mtu acl-state acl fm cluster datazone
24:de:c6:af:33:a0 Diekgait.nl N/A 192.168.1.8 g-HT ap 1/19/19 0 AP01 0 4h:16m:39s 1500 - 68 T no
24:de:c6:af:33:a8 Diekgait.nl N/A 192.168.1.8 a-HT ap 116/24/24 4 AP01 0 4h:16m:39s 1500 - 68 T no
Any idea?
Dennis Lansink • Security Engineer
Securelink Nederland
Re: 40 Mhz on ArubaOS 8 and ap-105
The AP-105 doesn’t 80MHz channels , it is an 802.11n AP
You need an 802.11ac AP 2xx or 3xx
Thank you
Victor Fabian
Lead Mobility Architect @WEI
The AP-105 doesn’t support 80MHz channels , it is an 802.11n AP
Thank you
Victor Fabian
I'm not asking for 80 mhz, but for 40 mhz. Right now it will only do 20 mhz.
Here you go:
http://www.arubanetworks.com/pdf/technology/whitepapers/requirementsfor80211ac.pdf
Thank you
Victor Fabian
Here you go:
Thank you
Victor Fabian
Sorry misread your original request
Can you validate that the 802.11a radio profile has wide-channels enabled
Also under the SSID > HT SSID profile the 40 MHz and HT is enabled
Get Outlook for iOS
Thank you
Victor Fabian
Get Outlook for iOS
Thank you
Victor Fabian
See here:
rf dot11a-radio-profile dot11a-dl
csa
dot11h
arm-profile arm-dot11a-dl
max-channel-bandwidth 40MHz
eirp-max 127
wlan ht-ssid-profile ht-ssid-dl-test
wlan ssid-profile ssid-dl-test
essid Diekgait.nl
opmode wpa2-psk-aes
dtim-period 5
a-basic-rates 12 24
a-tx-rates 12 18 24 36 48 54
g-basic-rates 18 24
g-tx-rates 12 18 24 36 48 54
max-retries 4
max-clients 128
wmm
wmm-vo-dscp 46
wmm-vi-dscp 26
wmm-be-dscp 0
wmm-bk-dscp 8
local-probe-req-thresh 10
wpa-passphrase *****
max-tx-fail 25
g-beacon-rate 18
a-beacon-rate 12
qbss-load-enable
If you want so see more I have attaced the config in the first post.
