Occasional Contributor I
40MHz bonding won't turn off in 2.4GHz
I've got about 20 AP-105s attached to a 3600 local, with 3200 acting as master.  I've got HT turned on in both 2.4 and 5 radio profiles.  ARM profile is set to a-only for 40MHz channels.  However, some APs are bonded on 2.4.  Is there some other setting I need to change to get this to work properly?
btvnapAdmin3c-A4:61  Admin Office  10.100.62.81    2            AP:HT:7+/23.5/23.5   0            AP:HT:44+/23/23      105      2      8d:8h:27m:24s   N/A
Re: 40MHz bonding won't turn off in 2.4GHz
Do "show ap-group "Admin Office"" and note the 802.11a radio profile and 802.11g radio profile in use.  Then, do "show rf dot11a-radio-profile <name>" and "show rf dot11g-radio-profile <name>" (where <name> is the name in use above).  Are they using the same ARM profile?
Then, do "show rf arm-profile <name>".  Is the ARM profile for the dot11g radio profile set to allow only 40MHz channels in the "a" spectrum?
If things still look right, check the software version.  I haven't seen any bugs like that, but it may be possible.
AP group "Admin Office"
Parameter                                Value
802.11a radio profile                    default
802.11g radio profile                    default
802.11g radio profile "default"
Parameter                                      Value
Adaptive Radio Management (ARM) Profile        default
(btvnapfdc02) #show rf arm-profile default
Adaptive Radio Management (ARM) profile "default"
Parameter                         Value
Assignment                        single-band
Allowed bands for 40MHz channels  a-only
AOS 6.1.2.5.
So if it's configured correctly, then I guess I have to call support.
Make sure you haven't done any AP-Specific configuration.
No AP specific configurations.
type "show ap config ap-name <name of access point>" to see where that access point is getting its configuration from for that specific parameter.
I rebooted the APs a second time and they came up properly.  Don't know what got stuck, but it's all good now.  Thanks everyone!
