Frequent Contributor II
4306G and AP 105 issue
Hi all, it's probably something basic im missing. 4306G controller, vlan 1 only, AP105 directly connected, it gets an IP address via DHCP, is pingable but does not show on the controller  ??
Any clues ?
ACMA/ACMP
Re: 4306G and AP 105 issue
Check the control plane security settings. If enabled, add the AP's mac address to the whitelist.
Or just disable the control plane security setting.
