Occasional Contributor I
4G uplink with controlled AP
Hello
Is it possible to use a 4G uplink with a controlled AP?
It seems it is only possible with an IAP or a remote AP correct?
Or is there a way to make this work?
Re: 4G uplink with controlled AP
When you say "controlled AP", do you mean a Campus AP?
Thanks for the reply
Yes, i am using the Aruba 325 AP's.
This probably wouldn't work more because one of the protocols used for a Campus AP, GRE, will not work across a NAT boundary.  I'm sure your 4G connection would use some sort of NAT.
Oke tath is clear.
So my setup is:
2 controllers and Aruba 325AP's.
Now i need AP's on a remote place witouth an ethernet connection possible.
So our solution is to use a 4G uplink with indeed the use of NATing to reach our existing LAN.
The only solution is to use a remote AP then? Or am i rong? Because i want the controllers still to manage them.
@Aruba_user wrote:
Oke tath is clear.
So my setup is:
You can configure your AP325 to operate in RAP (Remote AP) mode. Basically, the AP in RAP mode is simply encapsulating the PAPI and GRE traffic inside an IPSec tunnel for traversing NAT and public networks. RAP mode is still controller managed.
Charlie Clemmer
Aruba Customer Engineering
I need an IAP to do that no? I think it is not possible with a campus AP.
'Remote AP' is a campus AP operational mode. It is not related to IAP.
Charlie Clemmer
Can you point me in the right direction to turn a campus AP into a remote ap?
