650 Firmware
WHello all,
my 650 controller  has an expired cert and I try to find a new firmware (if that solves the issue I dont know but what do one do?)
current sw is 6.2.1.4.
even tho the controller is eol I would like to get the latest one, if any, and give it a shot.
so, how do i get the firmware? I tried registering my controller on aruba support web, but noone is gettibg back after the stipulated "3-5 days".
please help
/B
Re: 650 Firmware
Hey, if you have an expired certificate then you will need to obtain a new certificate for the device. Recently the certificate which ships with Aruba controllers was revoked, so you may actually be facing this issue.
https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Re: 650 Firmware
the newer firmwares will provided a self signed certificate but yes you need to either purchase a cert or use the self signed
#AirheadsMobile
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
