Super Contributor I
650 and AirGroup
Hello All,
I was ding a POC today and found after upgrading a 650 to 6.3.1.4 it did not have the Airgroup tab. I was told it is only available on 6.1.3.6 only and is also not recommended for Airgroup. Anyone can enlighten me why is it so, does Airgroup take up a lot of resource on the controller causing it not to be available on the higher version?
Normal Guy
Re: 650 and AirGroup
AirGroup is not supported in 6.3+ on the 600 series controllers. It is too resource intensive for the older hardware to handle.
Tim Cappalli | Aruba Security
Super Contributor I
Thanks Tim for the prompt response, the Airgroup should be universal across platforms since it was previously supported on 650. Seems like another RF Plan issue.
Normal Guy
All of these details are very well documented in the release notes and user guides.
It's impossible to maintain full feature parity across new and legacy hardware platforms. Especially when these new features are all very resource intensive.
Super Contributor I
Thanks Tim for the detail infromation. Lazy me. :)
Normal Guy
