Frequent Contributor I
7000 Series Controller - Replacement for 3000 series?
Can anyone please suggest if we can quote 7030 in place of 3400 controller? 7000 series being the cloud services controller make these any different from the 3000 series? Are 7000 series controllers only meant to use in branch offices or small scale environments?
Thank you.
Re: 7000 Series Controller - Replacement for 3000 series?
Cloud services controller is just a new name. These controllers have feature parity with the 72xx controllers.
You could definitely replace your 3400 with a 7030. They were designed for small/branch but they will work in any environment as long as you don't hit capacity of the box.
Tim Cappalli | Aruba Security
