Regular Contributor II
7030 controller license question
Hello everyone,
I have a 7030-US controller, (by mistake) I purchased a 16 APs license with and 24access points-I should have bough more license-
I connected 16 APs initially to the controller and they work fine, later I adder the other 8 APs to the controller and the also worked fine!!
I was surprised to see that the controller is handling more APs that the license limits!! After that I added two more APs but the would show up as not licensed when I run the show ap database command.
Can someone explain to me how is that kind of licensing situation is being processed please?
Re: 7030 controller license question
What version of code?
Is this an independent master controller?
Tim Cappalli | Aruba Security
Running 6.4
I have a master-local setup. Master is the licensing server on centralized licensing.
thanks,
So it is likely pulling the licenses from your other controller.
Not sure why, I have no license on the other one. The show license output has nothing on the local controller.
Can you post the output of:
show license aggregate
Where all APs connected to one controller? if not that may be due to an error caused by centralized license configuration , because in Centralized license server configuration , the client can save his license configuration for a month after a disconnection , so maybe caused by that.
But any why normally you should bay more licenses.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Aggregate License Table
Hostname              IP Address  AP   PEF  RF Protect  xSec   Module  ACR  Last update (secs. ago)
sfc01-awr02           10.0.0.11      0      0      0                 0            0         9
sfc01-awr01         10.0.0.10       16    26   26                 0            0         29
Total AP License Count                           :16
Total PEF License Count                         :26
Total RF Protect License Count                :26
Total XSEC License Count      :0
Total ACR License Count                        :0
When more than 16 APs are connected, are they completely up with radios serving clients? (no L flag next to them or amber lights...)
Yeah fully operational with no flags and clients connected to them.
