70XX serie AppRF and WEB CC supprot
hi ,
i read in the datasheet that Aruba Controllers 70XX series support AppRF and WebCC web filtering , but i can't found  those 2  parameters in the dashboard menu.
any help ?
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: 70XX serie AppRF and WEB CC supprot
Look at the following links:
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Dashboard_Monitoring/AppRF.htm
https://ase.arubanetworks.com/solutions/id/103
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
