Contributor II
7200 MC: 1G SFP in 10G SFP+ slot - LAG with built-in 1G ports?
Hi - My customer wants to use a 7200 controller, but has only 1G local switching capability.
Can I form a multi-port LAG to the controller by LACP combining the two 1G ports with some 10G SFP+ slots, which have 1G SFPs installed?  (the latter bit, on its own, is documented in the hw install guide:   "The ports support dual speed (1GbE or 10GbE) operation.")
Assuming this is supported, I take it there would be no problem mixing 1000Base-T and (say) 1000Base-SX in the same LAG...?
Re: 7200 MC: 1G SFP in 10G SFP+ slot - LAG with built-in 1G ports?
Should work without issue. You may want to hard set the speed on the SFP+ ports.
Tim
Tim Cappalli | Aruba Security
Aruba
Numpty Dumpty,
Its rare for me to correct Cappalli but in this case he is mistaken. You can form a port-channel/LAG using the two SFP ports OR the four SFP/SFP+ ports but not accross these two interface types.
Best regards,
Madani
Learn something new every day!
Tim
