Frequent Contributor I
7205 Controller Twinax DAC connectivity to Cisco Nexus
Has anyone had issues with getting a pair of 7205 Controllers connected to a Cisco Nexus core via Twinax DAC cables? Trying to measure the risk vs. saving 5k-ish in cost for 10GB-SR optics.
-n
Re: 7205 Controller Twinax DAC connectivity to Cisco Nexus
Which vendor's DAC cables are you using? That is an important data point.
Tim Cappalli | Aruba Security
I was planning on going with HPE Aruba, DAC-SFP-10GE-3M.
I can go another way if it is more stable.
Any thoughts?
Super Contributor I
Hi!
It´ll probably work, I do personally however prefer to have the vital parts of the controller under proper support to avoid any headaches and blame-games later on. Hence, I buy the Aruba ones.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
