Occasional Contributor I
7205 controller best practice and redundancy
Hi all,
could you clarify me some doubt with wifi implementation.
We have two 7205 controllers.
As I understood we need to set one of them to master, and another one as a local controller.
Local controller will terminate all AP, and master will heat the air.
1) Using two local controllers in this situation is not better solution than master/locl cluster?
2) If my local controller will failed - can AP register to master, or they failed too till local controller replacing?
3) licensing - should we put licenses to master controller (central licensing), or they should be placed to local one?
4) About AP VLANs - Aruba doc said, that "edge VLAN should not be dedicated to APs except in environments where 802.1x is a requirement". Does it mean that these APs recommended to place in to existed wired user VLANs? I'm planning to use dedicated VLAN for controller, and all APs.
Many thanks.
Re: 7205 controller best practice and redundancy
- Your two 7205s can be configured as Master/Backup Master (Active/Passive), Master/local (Active/Active).
- Both of these designs supports the secondary controller backing up the primary controller upon failure.
- You can put licenses on either controller.  Centralized Licensing will pool them together.
- You can put access points in any VLAN that you want, as long as they can contact the controller.
Hi Colin, thanks for fast response.
If I decide to run Active/Active solution I don't need to split my license pool?
I can use full pool on master only?
Do I need to split APs to different nets to support A/A mode?
Because if I use same net for all APs DHCP server unable to send different option to different APs.
Or I need to register APs once, and after that create two group with different  controller order?
In active/active and active/passive centralized licensing allows the access points to be shared between both controllers.  You do not need the APs to be on a different subnet.  You would need two groups to have access points on different controllers.
