*7210 Configuration Guide
hello can any body help me giving 7210 controller configration guide
Community Administrator
Config Guide
Sounds like you are looking for the AOS configuration guide.
Look here:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=8863
You will then need to select your configuration guide based on the AOS you are running.
Airheads Community - The best place to Connect. Engage. and Learn.
Valued Contributor II
Re: *7210 Configuration Guide
Hi Jamie,
Most of the features of Aruba Controller are Hardware independent and related to AOS version. which Image version running in your 7210 Controller ? if it is 6.4.X can download it from the support site.
Please let me know if you have any on finding and downloading the right doc.
Cheers,
Venu Puduchery,
