7210 SFP+ Issues
Has anyone else run accros problems getting SFP+ modules working in Aruba 7210 controllers?
No matter what I have tried so far, I am still only able to get the 10/100/1000 port to work.
I have tried this on 6.4.2.6 and 6.4.2.12.
I have tried Aruba (DAC-SFP-10GE-3M, DAC-SFP-10GE-1M) and Arista (CAB-SFP-SFP-1M).
All of the cables I have tried have worked between S3500 switches and Arista DCS-7050SX-64-F.
Here is what I am seeing:
(Aruba-7200) (config) #show interface gigabitethernet 0/0/1
GE 0/0/1 is up, line protocol is down
Hardware is Gigabit Ethernet, address is 00:1A:1E:01:EC:32 (bia 00:1A:1E:01:EC:32)
Description: GE0/0/1 (RJ45 Connector)
Encapsulation ARPA, loopback not set
Configured: Duplex ( AUTO ), speed ( AUTO )
MTU 1500 bytes, BW is 1000 Mbit
Last clearing of "show interface" counters 0 day 0 hr 5 min 1 sec
link status last changed 0 day 0 hr 5 min 1 sec
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input error bytes, 0 CRC, 0 frame
0 multicast, 0 unicast
0 packets output, 0 bytes
0 output errors bytes, 0 deferred
0 collisions, 0 late collisions, 0 throttles
This port is TRUSTED
(Aruba-7200) (config) #show interface gigabitethernet 0/0/1 transceiver
Module is SFP/SFP+
Manufacturer : Molex Inc.
Part Number : 74752-1301 , rev:
S/N : 312330216
Date Code : 130503 Lot:
Optional Signals : N/A
Supported Modes : 10GBASE-DAC-P, Copper Pigtail Connector
Wavelength : N/A
Cablelength : 3m
(NM-HS-7200) (config) #show interface gigabitethernet 0/0/1 transceiver
Module is SFP/SFP+
Part Number : 74752-1051 , rev:
S/N : 433032467
Date Code : 141126 Lot:
Wavelength : N/A
Cablelength : 1m
Module is SFP/SFP+
Manufacturer : Arista Networks
Part Number : CAB-SFP-SFP-1M , rev: 0002
S/N : XHC14481G1XJ
Date Code : 141127 Lot: 00
Wavelength : N/A
Cablelength : 1m
Any help is greatly appreciated. I have little time for a TAC case and no cell reception or available hardwired phone onsite. :(
____________________________________________
Brandon Hawley | ACMA, ACMP, ACDX
Director of Services and Engineering
DCTS | bhawley@daycintech.com
Re: 7210 SFP+ Issues
You need to use ports 2-5 for 10G
Tim Cappalli | Aruba Security
Well, I do feel a bit foolish now. I for some reason had it in my head that the 7200 series had only 2 10G ports.
