7210 controller wizards NOT working
I have loaded a 7210 controller with 6.3.2.1 now my license and AP wizards do not work - has anyone had this issue?  does anyone know of a fix?
Re: 7210 controller wizards NOT working
can you try another browser?
ACCP, ACCX #817, ACMP, ACMX #294
thank you very much!!! I was using Firefox now Google Chrome, whcih worked
Here is a list of supported browsers for future reference for 6.3.2.1 taken from the release notes
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
