7210 mobility controller OS
what is the most stable and recomended OS to run on 7210.
#AirheadsMobile
Re: 7210 mobility controller OS
I mean latest recommended OS
#AirheadsMobile
so is 6.4.4 considered as the latest stable OS
#AirheadsMobile
Yes. GA releases have been extensively tested in live environments and are
generally considered to be stable for most environments.
Tim Cappalli | Aruba Security
