7210 power & status Led goes Amber ?
Hi
i have Aruba contooler 7210 and i faced 2 problems :
1-sometimes 7210 restart .
2-power Led is Amber solid notice that this coloure not is guide.
3-Status Led is Amber solid .
please find attached file .
Ehab Atef Kamel
Network Engineer
Re: 7210 power & status Led goes Amber ?
If a controller is starting by itself, you should open a case with TAC to get it resolved.  It might be a problem with the hardware and TAC will have to replace it. Type "show version" on the commandline to see why the controller is rebooting.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
