Occasional Contributor I
802.11 connection failed due to status code 17
Hello.  I am getting the following error message on a couple of my APs (AP-125):
“Root cause:
Windows cannot connect to "<Name>SSID"
The wireless router or access point is busy.
Detailed root cause:
802.11 connection failed due to status code 17: Association denied because AP is unable to handle additional associated stations”
I've done sore reseach on line, but can't seem to find much on this issue.  Does anyone have an idea what's causing this?
Thank you,
Herb
Re: 802.11 connection failed due to status code 17
What version of ArubaOS code is this?
Long story short, it is used to load balance stations.  Turn off Spectrum Load balancing if you have it on and see if you still see those messages.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Software Version        : ArubaOS 6.1.3.9 is what we are running.
Thank you,
Herb
