Frequent Contributor II
802.11AC issues with clients connecting @ 802.11bg
hello airheads,
we are seeing issues with certain 802.11abg clients connecting to an AP275 Access Point but only @ 802.11bg. At 802.11a the client connects just fine. It just struggles to get any type of association on the 802.11bg band.thanks in advance. pete p.s. the client is a Honeywell VM3 with windows 7 embedded OS
Re: 802.11AC issues with clients connecting @ 802.11bg
Are these instant or controller-based APS?
funny you should say that my colleague has just tried an Instant IAP275 (VERSION 6.4.2.3) AND THE CLIENT CONNECTS OK. We are seeing this issue on our controler based AP
What version of ArubaOS?
version 6.4.3.7
Have you looked on the Dashboard Tab on the controller?  It is quite possible that your 2.4ghz RF is poor, or the AP is not hearing your devices well.
