Contributor II
.802.11N problem with AP 105
Hi all,
We have enabled the highthrouput on a controller and the band steering too. We notice that performance are reduced when we are on n Mode. There are no interference in the environment.
Any idea?
Best Regards.
Re: .802.11N problem with AP 105
We need to know:
- What client are you testing with
- Are you using encryption, and if so, what type
- What method are you using to test performance
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
- Intel Centrino Wifi Card capable N mode
- Windows 7 professionnal
- Encryption 802.1X
- Testing with ping the default gateway: performance in a or g radio: 3ms in n mode 6 ms sometimes even 50 ms!!!
- Testing with downloading a 200 MB file: in a or g mode : 1 to 3 min in n mode up to 10 min
Since wireless is a contention-based media, it all depends on how many users are in that VLAN, any interference you might have, if the current client drivers are up to date or have been tuned correctly.
There are quite a few things that affect performance.
Contributor II
-Driver Up to date
-1 client on the Wireless network
- No interference . I used Airmagnet to see this.
Thankx
Zakaria wrote:
-Driver Up to date
Thankx
There are quite a few things to check.  Please look at the thread here:  http://community.arubanetworks.com/t5/802-11n-Basics-RF-Design-and/Maximizing-802-11n-Performance/td-p/21886
